I have a 1986 k5 with a 700r4 transmission in it. My question is, just recently my truck has started reving to high RPM's before shifting gears. just the other day my tac went to 5000 rpms before shifting.. what could be the problem?
It is extremely important to have the cable hooked up and properly adjusted. The cable should be as tight as possible at wide open throttle and have a total travel of about 1 and 1/8 inches from idle to WOT. If the cable is disconnected the trans will not have sufficient pressure and rapid failure will occur.
