guz71
Took the truck in this weekend to have a new transmission pan seal put on because the old one was leaking just a bit and it was free. Tranny has about 3000 miles on it now and was working flawlessly until I had this done. So they put the new seal in and fill it back up and off I go. I immediately notice the truck shifting a little harder. Then it wouldnt shift till it built up a little more revs. Drove about 20 miles got home and parked it. Go to the store and the truck is now reving real high before it shift and doesnt want to go into OD. Take off from another light and it just keeps reving up and will not shift out of first. Reverse and first work fine but it engages pretty hard going into drive. Tried to manually shift with no luck. According to the guage the tranny was not getting hot either. Went home checked the fluids, fine. I also pulled out the gorvernor and the gear and it was in perfect shape So I am begging to think its something big. I dont think it could be the TV cable seing as it went out within 20 miles? Any ideas? I would just like to have some sort of idea before I tow in tommorow
