Your title says 4L60E, your thread states 4L60.
Greg Ducato will likely chime in and make the differences clear, but the 4L60E and 4L60 are completely different in terms of just swapping into a rig. "E" being electronic...no TV cable for input, needs a PCM/TCM for control.
700/4L60...there were some major changes in that transmission throughout the years, but I'm not sure if when GM changed the name to 4L60 anything major changed internally, or if it was just the name.
GM's(?) naming convention changed thus the reason it went from 700 to 4L60. 4 forward speeds, Longitudal mounting (RWD), 60 is a relative strength rating. thus why the 4L80E designation is so similar, but is a "stronger" transmission.
