700R4 brace question
nsxxtreme
Oregon
There are two steel rods the bolt to the bottom of the bell housing as a brace. I can't figure out where the other side bolts up to. Anyone have a picture of the underside of a blazer that might have these braces so I can see where they go?
One end goes to the tc cover and the other end goes to a plate that bolts under the motor mount.
Gus
Yup, should be that plate thats bolted to the motor on each side, then on the side a large bolt goes through the actual rubber mount. Look closely should be a spot on each. Ive got pics but cant post from my phone. If u really cant find any if u click on the link to my build thread and in the first post of that click on the link to my garage thread... Lol, they should be in there but its quite cluttered and my reason for startin a new one. You may be able to see them on my motor install too i cant recall
Gus
Crap! :doah:
Looked in my bucket of parts and now i see those brackets. Now gotta lift the motor so i can slide those under :(
Thanks :waytogo:
Nevermind I see what you mean, you put the outer bracket on that goes to the motor mount but didnt put that triangle shaped one on first... That blows...
Heres a pic anyway cuz i looked for it lol.
Yup, that sucked donkey balls. Leave it to GM to hang brackets off of brackets. I swear some dude must have had a full time job designing brackets!!!!
Yup had to jack up the motor remove the motor mounts then stick those brackets in. Aligning everthing back up sucked but its done now.
