xCaliK5x
I have noticed after my truck sits overnight, when I drive it in the morning, it will slip like crazy for the first 1/4 mile going up hill from my house, thats it. Other then that, it rockets off the line when its warm and shifts fine. I can let it sit for a few hours and its still fine. Sometimes it seems to hang between shifts (shift kit?). Fluid level is ok, no major external leaks (I get maybe one drip the size of a pencil eraser overnight, and not every time.). It has a B&M shift kit the previous owner installed, I want to pull the pan and change the fluid and filter anyway. I have researched the TV cable, sounds easy or a PIA to check and adjust depending on what forum I looked on. I also noticed a black switch that is above the pan on the pass side that looks lieka 2 pin switch, it ahs nothing conected to it. Any ideas where to start or a common problem? thanks in advance guys.
