3MAX
Which line is in / out flow? I'm hooking up a trans cooler and need to know the direction of flow. Looking where the lines enter the case, is the upper or lower one the outflow?
I cant ever remember,but the TCI website has a flow chart that tells you which is which...
Thanks!What I did to mine was I also replaced all the lines with push lock fittings and hoses. I ran lines from my trans to the radiator, to the external cooler, to an external filter, and back to the trans. Push lock hose and fittings all around. Cost me about $150 but now I have zero leaks. I would recommend doing it.
