700r4 grinding noise
eel757
south georgia
my 700r4 started grinding under deceleration the weird thing is it only does it in overdrive i tried to get it to happen in the other gears and nothing I'm pretty sure its time for a rebuild but I'm trying to hold off as long as i can.
That is an odd symptom, try gently pushing the transfer case shifter to 4H while this is going on and see if it makes a difference. Could be a transfer case snap ring or fork issue.
thanks ill give it a try next time i get it out on the highway a t case will be easier than a trans
