So some of you may recall my original 700r4 went out at 170xxx miles. My buddy who had a 700r4 laying around after he totaled his truck gave me his with only 5000 on it after a rebuild/upgrade. I installed it myself and followed details closely as well as installed a aftermarket trans cooler by B&M and a after market trans filter by Derale. I payed extra close attention to the TV adjustments and followed the instructions. After install it ran good for about a month and then i noticed it got a hard shift from 1-2. On my way home it would not hit 4. I instantly tried to pull off the freeway when third acted like neutral. After costing to a stop it down shifted and 1 and 2 worked then 3 for a bit and again like it shifted to neutral. I pulled over at the safest place and checked fluid and saw it was low so i added a quart and since i was so close to home i drove the back way in 2 by shifting into second. Since it was dark and raining i didn't notice till the next morning my pan had been dumping fluid.
I pulled the pan and resealed everything and adjusted fluid levels again. I noticed no metal shavings but alot of fine black dust. (im assuming clutch dust). still this didn't fix anything. o yea internal filter looked clean and had just been replaced.
Any ideas would be great! unfortunately if i have to replace the trans it is probably bye bye truck for me as i have no money and have already dumped to much into it. So any help would be appreciated.
I pulled the pan and resealed everything and adjusted fluid levels again. I noticed no metal shavings but alot of fine black dust. (im assuming clutch dust). still this didn't fix anything. o yea internal filter looked clean and had just been replaced.Any ideas would be great! unfortunately if i have to replace the trans it is probably bye bye truck for me as i have no money and have already dumped to much into it. So any help would be appreciated.
