scottsdale86
I had a perfect shifting and feeling trans in my 86 K10 until about a day or so ago. Today after a short 3 mile trip to drop my son off at day care I noticed that the trans was puking fluid out from the top of the transfer case. I checked the fluid level and it was low so I added a little and went around the block. All was fine and I parked it and went inside. this morning I went to grab some breakfast and it felt like it didn't want to shift out of first. I pulled over and checked the level and it was low again. Where I park my truck is on a slight grade so the front of the truck sits higher then the rear. I think the seal between the TC and the trans is letting trans fluid back into the TC. I am going to fix that but do you think I killed the trans? I didn't smell any burnt fluid or see anything abnormal on the dip stick but I won't know i suppose until i drop the pan and take a look around. Also the detent cable is adjust correctly and functioning as it should as far as I can tell but I am just worried I murdered this transmission. Any advice would greatly be appreciated.
