dudewiththeblue82
Registered Member
Hey all. I just recently had some trouble with my 700r4.
I lost all gears while driving down the highway. I recently rebuilt the engine (6.2 turbo) and transmission and replaced the old torque converter with a remanufactured one. So far I've put about 100 miles on the build and everything was going well, engine runs strong and the transmission was shifting perfectly. I put the tcc on a manual switch and would lock it in once I got up to speed. Now the other day I went to engage the lockup at about 55mph, but the locukup started engaging and disengaging very fast, so I quickly turned it off and kept on driving to town without the tcc engaged (about another 5 miles), and everything still continued to shift normally after that. On the way home though, I tried the lockup again and it caused the transmission to downshift from 4th to 3rd. I turned it off and it shifted back to 4th, and then tried again and it downshifted. After one more time of that I completely lost overdrive but it was still pulling good in 3rd without any slippage, but then about a half a mile down the road I completely lost all gears, like it just jumped into neutral. I borrowed a trailer to tow it home, and after sitting a while it went into gear fine and drove onto the trailer (with enough pull to even spin the tires with posi traction getting onto the trailer). Shortly after running though it lost gears again. I took the pan off and had pieces of metal shavings and torrington bearings. I'm thinking the insides of the torque converter went out? Everything was literally perfectly fine until the moment I engaged the tcc on the way home. I'd post pictures of the pan but I'm not sure how to do that on here, or if I even can.
Sorry for the long essay. Just trying not to leave out anything important
