Metal Twister
I just picked up a 92 k2500 for a donor rig for a street legal tube car crawler Im building. Is there a way to go to a full manual shift on the 700r4 without tearing into the ecu?
has a kick down cable on it. pretty sure its a 700?Are you sure you have a 700r4? I pretty sure a 3/4 ton from a 92 will have a 4l80e...
should be a tv cable not a traditional kick down. the 4l60 E was introduced in 93. so probably is a 700R4
.throttle valve cable, controls the line pressure inside the transmission based on throttle input via cable....
yeah, not that hard to set up...http://tvmadeez.com/article/index.php
OHHHH! Sounds like that could be a critical on how that gets adjusted up?
By full manual, do you mean a reverse manual valve body? If so, those sometimes eliminate the TV cable and run high pressure all the time. It just sits in whichever gear you select.
