The title pretty much says it.
I've got a 700R4 with manual TC lockup control via a dash toggle switch. If the trans is cool it'll lock right up at speed (and hold it). If I've been running around a bit and the trans is warm it will not lock up. It's of course self-defeating at that point because without lockup it won't cool down. I don't have a temp gauge installed, so I can't comment on exact temperatures involved.
My first thoughts regarding culprits are:
-hydraulic pressure gets too low when hot (pump clearances opening up?)
-Failing torque converter clutch
-Solenoid doesn't work when hot
-Something in the valve body failing when hot?
Anyone have experience with this?
