xenomarine
i know most of the basics it will take to swap my 208 to a 205, which is coming out of a 76 k20. though there a couple specifics i need some guidance to mount it to my 700r4.
the 205 is coming with a th350 that i am buying, along with the axles i'm picking up. i know i will need an adapter from th350 to 700r4, but i have also read that i would need to do some grinding, which i would rather not do but would if i had to.
i've found a couple adapters:
http://www.transmissionpartsusa.com/Quick_Swap_switch_kit_700_to_350_4x4_p/609-00007q35a.htm
i also heard of one from A & Red's transmission shop, part #7Q35A, which the shaft needs to be ground 1/8". thanks to jekbrown for that info from a previous post. i couldn't find this part on their website.
i just called up A&Red's and they said they only get the parts in used, and they are currently out of stock. so i'd like to ask all of you folks what you think the simplest and best solution is.
EDIT: also, before anyone says search posts, that's what i did for about 4 hours in the last 2 days without a conclusive answer
