Lunatic
Cleaning the surface is just a heavy wipe - Being that I dont use the RTV stuff. Removing the useless RTV on there right now should prove a learning experience though - Wire brush ?
In trying to describe "how tight" I torque my bolts, I palm a 1/4 drive ratchet with 6" extension, and snug until a small amount of tension is felt - I do not use the ratchet handle for leverage. Its not tight - Im sure if I tq'd it I'd be in the ball park.
Now, that cork gasket - Thats another creature all in itself. I knew it would fail but wanted to go through that motion to eliminate it possibly working. I snugged it as described above, but afterwards (initial leak returning), it was game on...and then game over.
The pressure switch in the picture - Is the wrong one, fitted to a reducer, to the transmis housing. The original was a pancake switch.
I just might look for this Permatex "Just Right" stuff......Ill assume an auto parts store is a good place to look intially.
Thanks for the input guys !
Troy B
Ft Hood, TX
Troy B
Ft Hood, TX
especially that stuff like we got that sets up like concrete and you can't hardly get it off
