700r4 PART NEEDED
Babaganoosh
1 ton status
Phoenix Arizona
No, im not asking for parts in the garage, but where to get it.:D
I need the plug for the lockup. (see picture below) I would like to get this in town, anybody know where I can get one?
Thanks guys.
Awesome, tomorrow I have to work so I'll just go over to the parts department. I was going to anyway just wanted to make sure.
Thanks Harley.
I don't know if they will have it but it is a good place to check for stuff like that.
Harley
Arizona TPI in Tempe might be able to get one for you if the GM Stealer doesn't have one. They deal with TPI obviously but that also means they deal with adapting it into cars and trucks with 700R4's & 4L60E's. If they don't have one the Junkyard will for sure. That is probably the cheapest route but you might have to do a little recon to find the one they have that is in the best shape.
Ecology is a U pull it yard on 27th ave and there is another yard just south of them that should have at least a few vehicles equipped with the parts you are looking for.
Harley
I get 10% off at the stealer ship, im praying they have one. If not I'm not sure what im going to do but i'll keep those in mind.
Thanks again Harley.
Even 10% off at the Stealer is still rape. I used to work in the parts department at Courtesy Chevy in highschool as a summer job. Stealer markup on parts is at least 100% on all parts.
Harley
True, I can't imagion it wont cost but maybe 10 bucks, but then again it is the stealership :doah:
GMPartsdirect.com
Metrodps said:
GMPartsdirect.com
You know whats funny, I just thought of going there 2 seconds ago. :haha:
:EDIT:
There catalog seems to be down =(
100% is nothing. GM SPO has to buy and stock parts from a bunch of suppliers and distribute to dealerships all over the country. From the price they pay the supplier to the retail dealership counter price you typically see about 1000%!
NAPA typically stocks the 2x2 weatherpack connector, but it might be the black one, which is intended for older IAC motors. The difference in color relates to the keying of the connector. If your old white one is in good enough shape to compare, you could cut more keyways into a black to make it plug into white. It would seal and work fine.
Just go to a pick and pull junk yard and cut one off another truck. I doubt if they would even charge you if you put in your pocket. Then just solder it and shrink wrap the wires.
