duece21
I just got done intalling new intake gaskets and cfm throttle spacer kit. I added the spacers from the kit that they give you to correct the TV angle, and I adjusted the TV cable by pushing it back in so valve was open then pushed the button in and forced the TBI to WOT (letting the ratchet adjustment move to it's correct position). The truck shifts smooth and sounds about at the right RPM's, but when I stomp on the skinny it won't lock in. Am I just not ajusted right? or is there something else here... Is it supposed to lock in every times you stomp the skinny?
Thanks Jesse
Thanks Jesse
