dirtwarrior17
Banned
alll im gonna say is read my first couple posts and read what rjf said....
dirtwarrior17 said:Not sure what you mean by 4 row but that sounds like a stock radiator. The radiator tranny coolers will still be about 45 degrees hotter than a seperate cooler.
Usually when a stock 700 goes with the stock cooling system hooked up (radiator cooler) its because they got too hot.
dirtwarrior17 said:IMO yours gears should be fine if there is no noise because in order for that to be a gear it would have to be completly stripped and if that were the case you would have metal all in your gears and wouldn't be able to go more than half a mile before it blew completly.
dirtwarrior17 said:I got one for ya.... if there are no "gears" then why is there filters for metal shavings? where could metal shavings be coming from? hmmmm ...... gears.
dirtwarrior17 said:that was a while ago now and almost all of the answers i give are either what i did to fix something i had to deal with or I will take an educated guess on a subject that I am just trying to help with and had some experience with, not say this is the answer on every post. Its gotten alot better in that aspect. Yeah you can go back and pick out posts from weeks ago but recently most of my answers will have questions in them if i don't know or I will say straight up i don't know crap about this but.... then give some sort of general knowledge just to get the thread moving... I am NOT trying to make you all think i know everything but i feel like I have to prove myself in some aspect because of the mini mull bs contest.
As for the 700r4 subject... read the whole post. I get misunderstood because of the bad posts in the first week. I am offering a solution because i have a 700 and have done a lot of research on how they work because I had problems with mine. What I wrote in this post(and others like this for example the starter one), is from real world experience and research. I know i have posted some real general crap and fought about it on old posts but somebody please show me a recent post where i got this "know it all attitude".
ever since this started, a few (won't name names) try extra hard to make me sound like a dumbass and im getting tired of it... statements like autos don't have "gears" is just one example.![]()
dirtwarrior17 said:I was giving him an answer to his post name.... dead 700r4? thats all He wanted to know if the whole tranny was gone and i basically said no because of what it was doing and tried to explain to him that it couldn't be the gears and then said it might be a servo... I also said i forgot about the reverse clutch pack. I am not sure but i beleive it has nine clutch packs.
When you say gears what do you mean? I think it has 4 planetarys and one sun but im not sure. I never said i knew any of that and i don't need to becuase i am not telling him for sure what is goin on you are. Moving gears whether planetary or not create very small metal shavings that along with others get picked up with the filter but some still make it to the fluid. Not chunks, shavings. Those words are right from 2 very knowledge trasmission shops one being the biggest we have up here.
convinced yet kid? i specifically remember reading one of your posts that said that you had taken it to a shop, and it cost you $900 to have the 700R4 rebuilt. that's fine, had you not bragged about how much "knowledge" you have about the 700R4, you know, with its 9 clutch packs, 4 planetaries, and one sun gear. damn, with all that stuff in there, where do you have room for all the gears. RJF asked you to keep your opinions to yourself when facts were requested, you really should think about actually doing it, rather than saying you arent, but continuing in your "old ways"dirtwarrior17 said:I posted on this because i have a 700 and spent alot of time finding out how it works to correct my problem.... What posts are you talking about? the whole 396 crap was a bunch of bs where i said i was wrong and it all got way out of proportion...and i wasn't the only one invovled. Its the things like axles, brake boosters, etc that i don't really have a clue about but i know the 700. You would be suprised how many things i have had to fix on that truck in a coulple years.
You also have to remember right now, your still in training, he has decorated stars.And im still learning myself.dirtwarrior17 said:alll im gonna say is read my first couple posts and read what rjf said....
call any tranny shop. ask them what the most common reason a 700 goes.Usually when a stock 700 goes with the stock cooling system hooked up (radiator cooler) its because they got too hot.
I have been running 35" boggers, 4.10's, and built th700 for a couple of years now, no problems to date, not even an overheat. I do however think that anything taller than 4.10's (3.73's and numerically lower) would be causing too much heat with a Th700, on 35's of course.flatline said:Any other suggestions for the 700R4 on 35's ?
stop what you're doing then.dirtwarrior17 said:
None of these prove anything.... I am real tired of this.
you took a guess at how many it had, which was followed by a response from TJ telling you how many planetaries it actually has.
exactly my point on the gears. the gears do not strip as you suggested. they do not strip because they do not exist. the clutch pack frictions and steels wear to the point that they can no longer be engaged, they just slip.
dirtwarrior post..
you have been corrected on the shavings in the oil as well, it comes from the clutch packs that you apparently did not know about. planetary gears do not wear enough to produce a significant amount of shavings to even be noticed in the oil. something about being hardened gears that keeps them from wearing.![]()
dirtwarrior17 said:I guess the techs at nor cal trasmission are wrong.![]()
anyway, one thing to consider if you don't want to add a sender to your pan is they make trick in-line junctions now that you basically plumb between your tranny and the cooler. Looks like a billet aluminum "T" sorta, pretty bling. I saw them in a recent fourwheeler/petersens but I forget who makes them. In any case, this is a great mod for anyone who is already replumbing their tranny cooling lines anyway and negates the need for messing with the pan (which, who knows, you may need to swap out at a later date for some reason, losing the sender mount). When I replumb my tranny lines (next paycheck!) I'm gonna use one of these...maybe I'll do a write-up or something for the tech forum.
