700r4 tailshaft, bushing and yoke
eagle mark
- In Memoriam -
North Idaho!
I got a 90 Chevy 2wd Suburban and it's got a lot of wear/play at the tailshaft where the yoke comes out. Where can I get a tailshaft or bushing and a yoke for this?
I would pull the driveshaft first and check the yoke for wear at the contact point where it meets the bushing. The bushing can be easily replaced by any trans shop and will save you the expense of replacing the whole housing. If you have a bushing that has spun in the housing then replace the whole thing. I can help you with the parts if you need them, send me a PM if I can help.
I've got a press. Do I need more than that to put the new bushing in? No where to get the bushing other than a trans shop?
It's worn pretty bad with lots of play. I figured yoke and bushing
If you have a bushing/race driver that will fit the diameter of the bushing then you can certainly press this out yourself. The bushings are much softer than the yoke so chances are good that the yoke is OK. I can send you a bushing if you can't locate one locally. Some parts stores can get transmission parts so that may be worth a try.
Very kind of you to offer! :D
If I fail to locate one I will contact you. But there is a transmission parts place in Spokane that supplies all the trans shops here in Coeur d'Alene that I have bought parts from before so I think Ill be able to get it...
