Blazr77400
sold
This is a 700R4 out of my k30 crew cab. It has an Advanced adapter 32 spline output shaft and spacer to make it a direct fit for a th400 trans. Its the same length so no driveshaft or crossmember changes. The trans has about 40k on it. Has a heavy duty low stall torque converter (built in Idaho). Also has the updated clutches and billet servo. Also is a lockup trans. Putting a different motor in and it came with a trans on it so I am not using this one. Over $3000 into this trans when built and should handle up to 500hp with a big cooler. $900
Also have the 205 and figure 8 adapter that was mated to this trans.
$350 for 205 and adapter.
$175 for just the adapter.
$250 for just the 205.
$1200 for trans, transfer case, and adapter.
