WJACKSON11X
91 V1500 With 182,000 miles. Not sure if its the original trans, I'm assuming not
When I purchased the truck, I noticed a long 1st gear with a not so smooth shift into 2nd. After the axle swap and lift it seemed to get worse, assuming because of the lower gearing (4.56). I adjusted the TV cable by depressing the tab and holding the throttle pedal to the floor. I now get really smooth 1-2 shifting, but I feel like it may be shifting too soon between gears, especially into OD. Any ideas? It just seems to go into OD prematurely, and wants to "hunt" for OD while going up small hills.
