Flhftw
Registered Member
I installed a Holley carb with the recommended gm kick down bracket and I am told if the kick down cable is not adjusted properly it will burn up the transmission in anywhere from a couple yards to 5-10 miles. If this is true, can someone verify this? I drove it probably 4 miles before hearing this information and haven’t driven it since because of other issues. I’ve since adjusted it, just curious if I will be dealing with other issues once I get this truck back on the road. Thanks
