goathearder
So, I finally buttoned up the 700r4/np205 swap in my 73 (originally th350/np203) last night and went for a test drive and the tranny won't shift out of first gear. It fine in first and reverse but I can't get anything else out of it.
After a bunch of research, this seems like a common problem with either a stuck throttle valve of a malfunctioning governor. I am going to pull the pan tomorrow and check the throttle valve and also pull the governor out to check that and hopefully that fixes the issue. I should mention that the TV cable itself was adjusted properly and just to take it out of the loop completely, I disconnected it and still didn't get any shifting.
My question is this, is there ANYTHING else I should check for while I have the pan dropped? Luckily I got a pan with a drain plug but I would really like to only drop it once if I can so I am willing to go through anything I can in there while its off.
This tranny was rebuilt but then sat with no fluid in it for over 6 months before I purchased it (which makes the stuck valve even more likely) so if that would potentially cause issues anywhere else let me know what to look for.
Thanks,
John
Thanks,
John
