Looking for the stock brackets for a 205 transfer case that fit a 71 Blazer on the passenger side. Thanks, Joe
Are you keeping the truck stock and driving it on road only?Looking for the stock brackets for a 205 transfer case that fit a 71 Blazer on the passenger side. Thanks, Joe
The problem is it holds that side very well and then you twist it up off road and the engine and transmission twist and the adapter breaks or the transmission tail breaks.Truck has a 2" lift planning on doing some off road use. Is there an after market bracket that would be better. I have the DIY4X motor mount and stock transmission crossmember.
But if you still want it I will sell it to you.Truck has a 2" lift planning on doing some off road use. Is there an after market bracket that would be better. I have the DIY4X motor mount and stock transmission crossmember.
That's better if you can do that.I do have the long rod for a 208 case that bolts to the back of the motor that I could modify. That way everything is more or less one unit.
I'm using a TH350. It has a TCI pan and a torque converter cover from a 700R4 to help strengthen the case. Also using the braces that go from the motor mounts the torque converter cover. Looks like
the long brace will work fine with some modification. Thanks for your information.
Is the 350 case a K-case?I'm using a TH350. It has a TCI pan and a torque converter cover from a 700R4 to help strengthen the case. Also using the braces that go from the motor mounts the torque converter cover. Looks like
