You don't drive off of the tach? hmmOk, another question... How do I calibrate my speedometer? Count teeth in rearend, then what? I'm running the stock np205. engine will be a blueprint 383, and a TCI maximizer th350. Had a 350/th350 before.
also, when I go to install new engine and trans, that maximizer should drop right in, correct?
@6872xtc this ones for youalso thinking about acessory brackets... I'm going to stay with a short water pump, but would like to move my alternator to the pass. side. No AC.
I understand that you can buy different blocks that screw into the tcase, that the speedo cable hooks up to, but how do I figure out which one i need? And yes, I used to just use the tach. lolYou don't drive off of the tach? hmm
THere's an inline correction that goes onto the tcase end to correct the speedo
You will need to find the amount that the speedometer is off, change that number into a percentage. This will let you know the amount of percentage of correction needed.Well I never changed it when I put the 35s on it, so I know it's quite a ways off.
