This is the ZF bracket:
This is the Saginaw bracket:
My understanding is that you can bolt a ZF pump up into either one with an adapter for the Saginaw bracket, but the Saginaw only fits in the second bracket.
These brackets came out of a motorhome that burnt to the ground.
The second set shipped this morning, it has a Saginaw pump in it already.
I also tried to use this on the K10 during the 8.1 swap but it wouldn't fit. Next time you get a UPS truck in with a 4.8 or 6.0 look at the P/S pump. We used this same bracket to mount the ZF pump to the LS style bracketry as well.
