71 Chevelle SS clone - 8.1L Swap
Cool update Russ!
where are you plumbing the pcv into?
I had mine (on the Vette 355) plumbed from a rear block breather hole into the base of the carb, and it would suck oil in the base of the carb under hard acceleration.
Cool update Russ!
It's hooked up from the base of the throttle body down to the distributor hole. I figured I can put a self draining catch can on the firewall if it starts sucking oil up from inside. Or try to put some kind of splash shield over the opening on the bottom of the intake.
