Memorial Day Slam - 5/31
Ok so me and my dad spent the first part of the morning cleaning the garage so we could back the '73 in since the top is off.
Then the work on the '71 began.
We pulled the old points dizzy and stabbed the AC Delco HEI we had in the shop. Found a stock set of wires that would work and hooked em up. Found an ignition 12v source and wired it up. Just set the timing close (finger over #1 spark plug hole, find compression stroke when finger gets blown out
). Here's the video of it just cranking on starting fluid:
[youtube]MT0YOvKV4-M[/youtube]
Tried some more, figured out we weren't getting fuel to the carb. Fuel pump was seized. Quick run to Autozone, new fuel pump on. Ran some extra fuel line into a gas can sitting on the fender under the hood, and took it for a spin down the driveway
Dad said he was just letting it idle in Low going out, we're still amazed by how low that gear is, seeing that we've never seen one with a four speed in person. He says the clutch is grabbing good, but the brakes are pulling to one side.
We decided to just put some gas in the tank and see how it would do, ended up clogging the fuel filter. We're gonna try just swapping filters til it cleans up rather than trying to drop the tank. It's cheap and easy.
Cut the mudflaps off too. Those were ugly. haha
So here's what will be accomplished soon:
-Fix exhaust leak(gaskets)
-Change the oil
-Fuel filters
-Electrical/vitals(lights, gauges)
-Check brakes
-16" steel wheels to run tires we got for free
-Front trim and grille
-Drivers side mirror, reassemble DS door
-Get Registration and Inspection
This'll get us roadworthy and inspected.
