CUCV2
5/4 ton fun
Still getting the parts together for the steering. Ordered up a Borgeson shaft for a 93 Dodge because I am using the column from it and thought I might be able to use the Dodge steering box as well. Also, have a PSC steering box set up for hydro assist as a possible option. Got the Borgenson shaft and tried it on the PSC box. Apparently, Dodge uses a 30 spline shaft and Chevy uses a 36 spline shaft to attach at the steering box. So, I was just going to use the Dodge steering box but it was a rusted mess and set up for the push pull type of steering. I have a crossover set up ready to go in and the PSC box is set up for crossover. Ughh. I called up the guys at PSC to see if they could help me out. And what I thought might be an issue really wasn't. They are going to send out a 36 spline end to fit on the Dodge shaft. They were even good as far as sending the 30 spline unit back for credit. Thanks PSC
. When that part gets here, I should be able to get the steering put together. In the meantime, I will get some power steering hoses made up to plumb the Dodge power steering pump to the Chevy steering box.
Also, checked out some Dakota Digital Dashes. They are pretty sweet.
http://www.dakotadigital.com/index....tegory_id=662/home_id=-1/mode=prod/prd776.htm
The classic dash units are nice too.
http://www.classicdash.com/shopping...ack-6-Gauge-Panel-with-Auto-Meter-Gauges.html
. When that part gets here, I should be able to get the steering put together. In the meantime, I will get some power steering hoses made up to plumb the Dodge power steering pump to the Chevy steering box.Also, checked out some Dakota Digital Dashes. They are pretty sweet.
Still toying with a couple of ideas like a different intake plate, looking for another intake horn, or a custom intake horn. Enclosed a pic of how tight it is and the steering finished up. Might just start working on the brakes until I can find an intake horn. Ohh, the humanity...
