I replaced the leaking freeze plug even though I never found any water leaks. The rear main seal will have to wait until I get the tranny back in. You just need to remember that even though you drain the radiator, doesn't mean the motor isn't full of water. That sucked when I popped the plug out.
Also, after a long fight finding the right clutch, I got on in there. I had a way overpriced centerforce in there at first and then came to my senses that I didn't really need an extra grabby clutch. $450 for a clutch is just wrong.
The problem I'm running into now is the slave cylinder bracket. The bracket from AA is mounted to the bellhousing ok with a washer but the recommended slave had mounting holes that were not even close to fitting on the bracket.
One problem may have been that they recommend a 85 slave and I wanted to use a later version because I'd heard the older version master cylinders had an angled mounting foot that didn't work right in a first gen. I didn't want to try using an 85 slave with a 95 master so I got the 95 matched pair and drilled the bracket to fit the slave. It seems to fit fine even with the oil filter right next to it.
The problem will be adapting the AA replacement slave pushrod to the 95 slave cylinder. Since the AA provided clutch fork is originally designed to be used with a mechanical linkage you need a way to engage the hydralic slave pushrod onto the mechanical fork. It sounds more complicated than it is.
The 95 slave uses a plastic bore in the cylinder and a plastic bushing on the pushrod. The diameter is smaller than the older versions. The AA pushrod is all metal and I'm worried it will goof up the plastic bore in the slave. So the plan is to take the plastic bushing from the 95 pushrod and adapt it to the AA pushrod.
I'm thinking it will be a smart idea to get the master and slave working well before trying to put the tranny in. I've heard there can be some adjustments to the throwout bearing necessary.
Anyway that's it for now. More next week hopefully.
