Just what it says. Looking to get the complete assembly from where the gas cap mounts to where the return and fill soft lines connect. THe metal parts that go through the body to below the floor pan. Anyone?
I might have a spare. Can check later.
Damage like that is why I went with a flush mount gas lid. Also after I did damage the left rear corner, I used kids blow up sport balls to push the dents out the best I could, The football worked well. Just deflate them have a compressor hooked up with and inflate needle attached the ball and shove the flat ball where you want it and inflate, then let air back out and move around and repeat as needed. May not get all of it out but did a good job on mine.
I need to try that. not big dents about 8" across and no metal kinks. looks like someone punched the area several times with the palm of their hand. Of course good scratches in the dent's paint.
This is what I got. I'll be using the best one obviously, but they are all decent. The one on the left is the one I'll probably use. There is one there that's already cut in half.
The one on the right is the one cut in half I believe.
If one interests you, make me an offer. The one of the left is probably one one I will be using.
