I'm the guy dealing with "a ton of rust."
What everyone else is saying is true. If you've got rust in one spot, odds are it's hiding everywhere. Mine didn't look terrible (for a 40 year old Michigan plow truck), but even I found spots that were bad I didn't know about.
If you look through some of my pictures, you can see I pretty much cut everything away down to the firewall. Even parts of that are getting replaced now. With everything I've replaced on the tub, I could have built one from all aftermarket parts by now...which I pretty much did. Regarding those aftermarket parts, they seem to be fitting pretty well for me. Not sure if it's because I replaced everything and am not trying to line up with factory stuff, or if they've gotten better.
Best thing you can do is make a plan and stick to it. I went into my project knowing that I'd replace most every panel, so I wasn't too bummed out when I had to buy $5k worth of sheet metal. Rust repair by far takes the longest, especially when you are trying to cut back into good metal on the factory parts, then line the new aftermarket parts up. I'm just over two years into mine and am just now coming out of it. Sure, life happens and you need to take a step away every now and then, so you will loose more time then you think. By having and end goal in mind it helps to keep you motivated.
When your truck ends up in half, either you did something wrong or are going all the way and doing it correct.
