About the feeling of the 4 cylinders thing, there are several things that could be causing that... The 2 main things that come to mind are either a misfire or your idle is set too low. If the truck sounds good and feels good when accelerating off of a stop and does not stumble or shake or anything and feels like it has the power that it should than its probably not a misfire. Try adjusting the idle screw on your carb and see if that fixes the problem, not sure what carb you are running but regardless the idle screw should be fairly easy to find, right near or on the throttle on the carb. I have had both problems with my 76 blazer. If you turn up the idle and that doesn't fix your problem than report back and give us an update. If you think it's a misfire than with the engine idling pop the hood and start pulling plug wires off the motor, 1 at a time, just pull a wire and listen to the motor to see if you hear a change in the idle and if so, put the wire back on the plug, this indicates that the cylinder is live, if you do not hear a change then you've found a dead cylinder, and that's your misfire. Hope this helps.
