I'm in need of the front frame crossmember that is riveted in place that is directly under the front of the oil pan. I'm thinking one from a pickup might be the same. Please let me know if you have one available. Thanks. I'm located near Chicago.
I'm not familiar with the 1st generations, but, I believe that's the engine crossmember. Time to call DIY4X or ORD.
Too bad I scrapped all my first gen brackets a couple of years ago.I'm in need of the front frame crossmember that is riveted in place that is directly under the front of the oil pan. I'm thinking one from a pickup might be the same. Please let me know if you have one available. Thanks. I'm located near Chicago.
