72 top on 71 blazer, Anyone?
chevy111
Sutter, California
I have a 71 blazer but would like to put a 72 one peace top on it. Is this possible? What needs to be done?
There are two tops out there for the 69-72 blazers. Single wall top, which is bolted from the top down, and a Double wall which is bolted from underneath the bed rail on up into the top. A blazer that came with a single wall top will have threaded pieces of steel lodged underneath the bed rail to bolt to.
I think that you can interchange them without much problems. You just need to see what kind of tops they are. and what it would take to bolt them down.
reply
Yeah thats what I want to do is change to the single wall top. I haven't had problems with my top but would like to have the convenience of taking the top off without removing the panels. Also I like the fact they have lights in them. And I have heard that the double walls can seperate and leak. I suppose you could weld threaded nuts at the bottom.
You could weld threaded nuts to the bottom, but you might have a hard time alligning the top to the bolt holes. Mine came with a single wall top and it has threaded plates that sit in a channel so that the plates can slide forward and backwards. This way, it has a little bit of adjustability when putting the top on. Remember that when the top is off, the body changes shape slightly unless you have a roll cage in there holding it all together.
