73/74 grille brackets
BigBK5
Registered Member
Does anyone have pics of the mounting brackets for 73/74 k5 front grille? I have a 74 with a square tube grille that doesent use the factory brackets. I think the brackets are there behind the grille,i just don't know for sure I have the original radiator support. I have built in brackets behind tube grille,and the center support,just don't know they are original 74 vintage.Im wanting to purchase factory style grille.
In the LMC catalog online they list grille support brackets for 79.99.
The LMC brackets (part number 2 on p.40 of current catalog) will give you places for 4 of the 8 screws and should hold it plenty good. They look just like my stock ones and those work good with the new aftermarket grilles.
If I take my grille off, I will post a pic of the supports.
My 74 just happens to have the grille off for new body mounts. Below are a few pics, let me know if you need to see pics of anything else.
I don't have the mounts that are near the headlights,maybe they interfered with the tube grille. Im assuming those are grille mounts farther towards center to the left of the c-channel part of the radiator support,i have those as they are not removable,they have two notches in them for plasic nut thingys.
