73-75 Header weatherstripping
Jumppr
Clovis, Ca
I need to replace mine and I’m looking at LMC Trucks. I’m just looking for the piece that goes on the top of the windshield frame. Is this the correct piece?
At some point I’ll need these as well, do you need both?
There’s two separate pieces of rubber along the top of the windshield frame. Both of mine are completely useless at this point.
One glues to the frame. Most Fwd.
The other ties into the door seals. Sits on the lip just aft of the first seal that glues on.
Then there is actually A flat piece that glues to the front flat surface of the top.
If you were ONLY ever going to use a custom bikini top attached to the frame with a Softtopper snap strip, would you still use both weatherstrips?
I don't know.....I'm planning to get a Softopper eventually, but I've never seen one up close so I'm not sure how it all connects.
I have the softopper but haven’t installed it yet so I can’t say either. I would think at least keep the aft seal that sits on the metal lip for protection.
I’d keep both and are available repop.
Plenty of folks running the softopper that should know.
