Cntymnty77
It’s worth a shot..
I still have mine and I am still too farIt’s worth a shot..
I thought about that as I was posting that.. I don’t mind a little road trip but that might be to far.I still have mine and I am still too far
I was trying to prevent having to cut them down but I might just have to. I’d like to find originals with all the brackets, tracks, etc.Why not get some newer ones with power windows and cut the top frame out
I am considering cutting them up and pulling the brackets, I will let you know if I do.I thought about that as I was posting that.. I don’t mind a little road trip but that might be to far.
Absolutely!!I am considering cutting them up and pulling the brackets, I will let you know if I do.
Down side is you are stuck with needing new door panels from a newer truck and lose the ability to use the originals without patching some holes.Why not get some newer ones with power windows and cut the top frame out
I believe that up to 1980 the door panels are interchangeable and there are power doors in those yearsDown side is you are stuck with needing new door panels from a newer truck and lose the ability to use the originals without patching some holes.
