Picked up some 01 Silverado seats and trying to figure out how to mount them in place of the stock seats. I searched but didn't really see an answer for the topless 73-75 K5's.
Obviously the holes don't line up and with the 73-74 having the rocker boxes I don't believe you can access the existing holes or new holes from the bottom, at least not on the rocker side, not sure about towards the transmission tunnel.
Unless there is any easy way to mount the seats, I'm thinking of making (hoping some one has already made them (Kurt
)) 1/4" thick brackets that tie into the original floor holes.
For the driver side I'm thinking the rear outer mount would curve up the floor to the outer seatbelt hole. The others would be some sort of triangle shape that uses the original seat holes and have a stud welded onto it or a bolt through it for the new seat to mount to. May need some bracing in-between the pieces.
Passenger side would need something different as there are only 3 mounting areas due to the original tilt seat. Thought of a 1/4" steel plate with studs may work if it was bolted to all three hole locations.
Thoughts or ideas on how to mount the newer seats due to the limited access under the floor?
I do not have full roll cage. Not sure if I will in the future. Just trying to get the K5 street drivable.
Possibly adding a Silverado center console in the future which I think shares the same bolt holes as the seats (would have to pick on up) or may go with reproduction original style console.
Thanks.
)) 1/4" thick brackets that tie into the original floor holes. For the driver side I'm thinking the rear outer mount would curve up the floor to the outer seatbelt hole. The others would be some sort of triangle shape that uses the original seat holes and have a stud welded onto it or a bolt through it for the new seat to mount to. May need some bracing in-between the pieces.
Thanks.
