73-80 cab mount parts
thedrip
Chattanooga, TN
Bought a poly kit, can't find my old body mounts. I need the steel cup/sleeve that goes in between the body and the upper bushing, for each of the rad support mounts, and all 4 cab mounts. I'm a dummy, I know I left these somewhere safe, but I can't find them now!
thanks!
thanks!
I'll see if i can find a set, I parted a bunch of trucks and I believe I kept those
much appreciated. Project with a deadline (a real deadline, I'm moving back to the mainland in the fall) is on hold right now waiting on these =)
I've got quite a few of those things in a bucket in the garage... From parting out a Suburban so I'm not sure if the rear cab mount is the same.
Its the same on a jimmy/blazer of the same years, but the suburban thing is a mystery to me as well.
I know I have the steel cups for the radiator mounts and front body mounts you need. I'm thinking the rear cab mounts are different than what is on a pickup though since these came off a suburban. If you don't find a complete set let me know and you can have them for the cost of shipping.
sorry but I was trying to locate them, this is all I found, my junk is a mess, I need to organize:o
Any chance one of those pairs is about 4" long? the rear mounts are significantly taller than the front four are.
the rear mount the steel cup is molded with the rubber, couldn't get it out.
I have it but i doubt you could use it.
i will keep looking to see if I find any more pieces, I know there was more but for some reason that is all I found in the box.
I have to be able to use the rear mount, it's required for the poly bushings. I'm not worried about removing the old rubber, I have a couple tricks for that. How much you want for all 6 (the 4 pictured, and the 2 taller rears w/ rubber)
thanks
thanks
Found the rears, and they weren't the ones I thought.
I am thinking $15 plus shipping, I need a zip code to see how much.
Does the flat rate box go to Hawaii too?
96720, flat rate is the BEST way to ship to hawaii/alaska. Only thing that makes living here reasonable =)
