this is my current hood i thought it was sitting like this cus its bent but someone told me its a hinge issue.
Well, both. The hood gets kinked 'cuz the hinges don't slide evenly.
You can see the kink in the metal that's right in front of where the hinge stops; it's a bit less than halfway across the picture.
When the hinges start to freeze up, you pulling down on the hood bends it right in front of the hinge. The stiffener kits brace from that point forward ... a good idea, but not so useful once you've kinked the hood.
I un-kinked one by carefully bracing it front and back and then pushing down on the bend. But if you have a new one, go with that... brace it, and DEFINITELY fix the hinges.
You might well be able to take off your existing hinges, soak them in penetrating oil to loosen 'em up, and then lube the heck out them -- as said, the graphite stuff works well.
If, once they're moving well, the are too loose, i.e. wiggle side-to-side, then you should replace them. I've replaced soem of my bad ones with "good", i.e. tight, used ones, and when they're clean and lubed they behave just fine.
-- A
