Wanted 73-87(91) Parts Wanted List, Long, for Multiple Projects
GonicGM
Seacoast New Hampshire
Large Tailgate Emblem ESC Electronic Spark Control
TBI 20 gallon fuel tank pipes/hoses from L&R sender to tank selector valve
1991 454 TBI braided hoses, supply and return
454 TBI heater hose non-A/C from throttle body spacer to core
OEM studded oil pan bolts for 454 BBC
454 Motor Mount Clamshells, Struts and Strut Plates
87-91 LH maroon seatbelt retractor, standard cab
87-91 V30/V3500 TBI Intermediate Fuel Feed Line from fuel filter to braided line.
87 GMC service manual.
87 GMC wiring diagrams.
Tan manual window door panels (clean) (81-87 old style) Scottsdale, or better yet Silverado/Sierra Classic.
Tan and red/maroon OEM floor mats.
Clean LH rear brake drum backing plates for 84-87 1 ton GM, some 88-91 R/V may be the same. These have the snap in style ebrake cables. Can be from 14 bolt FF SRW, DRW or Dana 70.
Camper Special stuff, Tie downs, dual battery harness and relay(73-91 old style)
73-83/84-91 Dually Bed harness, wiring protectors, rear red fender light.
OEM 30/3500 Series Tailgate Light Harness, tailgate and bed
Firewall insulator, non-A/C from 6.2 Diesel Truck(81-91 old style).
Rear spring shackles from 1973 +/- (folded with two rivets).
Harness, dual tank, upper, 87-91, TBI.
85-89 hangers from factory dual exhaust, carbureted truck with solid upper strap
Factory Under bed exhaust heat shields, frame or bed mounted.
83-84 Smog SBC 305 350 Truck Exhaust Manifolds
Rear Brake Load and Height Sensing Proportioning Valve
OEM Take-Off Clean Low Mile Rear Full Floater Drums, SRW or DRW
