73-87 Cab Corner and Heater Box
GonicGM
Seacoast New Hampshire
I'm looking for a passenger side OEM inner cab corner for 73-87 Chevy or GMC pickup. If not the majority of it, I would settle for the inboard vertical feature adjacent to the fuel tank. This feature is not included with any repro. I will provide image. Anyone got a junk cab around they can cut this off for me for $?
Also looking for very clean original steel non-A/C heater blower motor housing, engine bay side.
Check out Readymix's thread in the complete vehicle forum, he's parting an '87.
Im cutting up a 77 suburban soon. But I can't make sense of your picture.
What time frame are you to get it? Soon or asap?
The images are of a pickup cab corner, rear view and inside, passenger side. You will not find this on a Suburban. I'm in no ruch on the heater box blower motor housing.
the inner cab corner is avalible in lmc :dunno: I just was looking at my current catalog .
unless the 90* little section is what you want and its not part of it .
you should mark what you want and retake the pic .
you should make what you want and retake the pic .
You need to re-read first post. It is clear and comprehensive. Your response is not. I'm not looking for advice, just the part. The post stands as is.
ya know what to me its a bit vauge. there is a lot going on in that corner.
lots of guys here mark / point out / circle what the part is in pics or before the pic is snapped.
so I will never reply to your stuff again if your this snotty. :mad1:
just tryin to help was all . :doah:
I have a 1979 C20 I just bought for scrap that has a decent looking cab. I can check if the back of the cab is in decent shape. I also have several of those heater housings I'm sure.
Martin
Oh I got it now. I was thinking of the front cab corner.
I can certainly cut one out from the rear of a rust free truck but prob not worth the time
This one have didn't the bypass either. The motor is from A/C unit which is bigger, so I added the bypass and changed the squirrel cage.
