73-91 Square Body Parts Wanted, Long List
GonicGM
Seacoast New Hampshire
73-83 Fleetside bed harness
88 and older 4 Core Copper brass radiator from gas truck (replacement part number 730).
Drivers front manual window regulator (new or excellent)
78-87 OEM Radio Knobs
OEM studded oil pan bolts for 454 BBC
87-90 454 TBI Dipstick Tube
87-91 LH maroon seatbelt retractor (clean)
87-91 V30/V3500 TBI Intermediate Fuel Feed Line from fuel filter to braided line.
Rear DRW Hubs.
87 GMC service manual.
87 GMC wiring diagrams.
Tan manual window door panels (clean) (81-87 old style) Scottsdale, or better yet Silverado/Sierra Classic.
Tan and red/maroon OEM floor mats.
Clean LH rear brake drum backing plates for 84-87 1 ton GM, some 88-91 R/V may be the same. These have the snap in style ebrake cables. Can be from 14 bolt FF SRW, DRW or Dana 70.
Camper Special stuff, Tie downs, dual battery harness and relay(73-91 old style)
Caps, Warn/OEM manual locking hub, Dana 60, 3/4 turn, fairly clean.
SRW K30 OEM front hubcaps.
OEM Front bumper guard (bumperette) for 81-87, passenger side.
Front outer bumper brace, passenger side.(81-91 old style).
Silverado 30 fender emblems with studs in tact (81-91 old style).
Scottsdale 30 fender emblems with studs in tact (81-91 old style).
Sierra Classic 3500 fender emblems with studs in tact (81-91 old style).
73-91 Dually Bed harness, filler panels (inner to outer skin), wiring protectors, rear red fender light.
OEM 30/3500 Series Tailgate, Lights and Harness
Rear spring shackles from 1973 +/- (folded with two rivets).
Doug Thorley Tri-Y headers for small block or big block.
Harness, dual tank, upper, 87-91, TBI.
Front plastic wheel well fillers under front cab mounts (81-91 old style).
Rear frame rail tips from one ton pickup (81-91 old style).
Factory Under bed exhaust heat shields, frame or bed mounted.
454 Y-pipe from TBI 87-91 one ton 4x4 VIN V
NP203 OR NP205 Square 4 bolt flat front output flange.
4x4 Frame Brackets from 454 7.4
83-84 Smog SBC exhaust Manifolds
New England only:
Upper stainless/chrome grille trim 83-88
Clean or new 81-91 drivers front wheel well
Excellent chrome front bumper (81-91 old style)
20 Gallon Plastic Tank Shields.
Factory split dual tailpipe, catalytic converter, hangers and brackets from TBI 87-91 one ton VIN R OR V
85-89 factory dual exhaust, any pieces, from carbureted truck.
3.73 Dana 60 Front and Dana 70 HD Rear.
Clean OEM Sheet metal in Code 72 Apple Red(any 77-91 old style).
Clean OEM Sheet metal in Code 21 Light Blue(any 77-91 old style).
8' bedsides with square fuel filler door, 81-91.
Clean OEM 8 lug white rims, Suburban spares ideal.
OEM grey cardboard liner, behind seat.
CLEAN GM 16" Budd/Dually rims, tubeless.
Front bumper black plastic lower spoiler/air dam/air deflector. (81-91 old style).
Firewall insulator, non-A/C from 6.2 Diesel Truck(81-91 old style).
7.50R16LT Tires
Clutch and brake pedal assembly and hydraulic reservoir (85-91 old style).
Door Jamb rubber seals from Diesel Truck/Silverado/Sierra Classic(81-91 old style).
Clean pair (or individuals) of rear brake drum backing plates for 84-87 1
Dual tank harnesses, firewall back, RH fuel lines(any 81-91 old style)
OEM 30 Series Tailgate Lights and Harness
I have a good pair of drum brake backing plates with decent shoes off my 86 K30 when I did the disk brake conversion.
I also have a working dual tank selector valve only no wiring if you need it. It is from a 1986 6.2 diesel.
Shoot me a PM.
fender emblems
Not sure what you are going for, a high end restoration or a driver but I have brand new in the package OEM Scottsdale30 & Silverado30 fender badges. $500 per pair! I may have some used ones available also, will check on those before I quote a price. if interested, I can send pics if you want!
fender emblems
Thank you for the reply. This truck once completed as planned will not be garaged and will likely have a plow on it. NOS will probably not be realistic. Thanks for the offer though. Good used with pins in tact would be a sensible option. LMK, Thanks again!
Small block intake manifold vacuum fitting from behind carb from loaded mid 80's 4bbl C/K
Tall tan kick panel(any 81-87 old style) drivers side needs to
be non A/C.
Tan manual window door panels (clean) (81-86 old style) Scottsdale, or
Tan door panel pull straps and map pockets (81-86 old style)
Tan OEM floor mats
Camper Special stuff, Tie downs, dual battery harness & relay(73-91 old
style)
stock 10 bolt/dana 44 front u-bolts, 2.75" or 3.00" tube
Automatic shift indicator needle and cable
Non-A/C glove box with untorn hinge
New England only:
OEM Doors in Code 72 Apple Red(any 77-91 old style)
OEM Front fenders in Code 72 Apple Red(any 81-91 old style)
85-88 factory dual exhaust, any pieces, from carbureted truck.
Front bumper black plastic lower spoiler/air dam/air deflector, 4x4 or 4x2. (81-91 old
style)
Frame mounted receiver trailer hitch.
Clean OEM 8' bedsides with square fuel filler door, 81-87
I am going to be parting an 82 Crew this fall. Its a Cheyenne so not loaded, but I think I have a set of tan Silverado door panels as well. I think I have most of the items in red. I will update when I start pulling things off of it.
Any of this become available?
No sorry. I didn't have any hits on anything with the truck part out so I decided to keep it. I am currently deployed so I can't even tell ya what I do and don't have on hand anymore.
I've got rear spring hangers, but I'm not sure what you mean by folded and two rivets. I'll look at them tomorrow and take some pictures if you're interested.
As ad states, I'm looking for rear spring shackles, not hangers. 72 and older used the style I'm looking for, may actually be the same.
I've got drw rear hubs. PM me what you want to pay for em. Shipping is probably about 50 bucks.
