So ever since I got my 73 the gas gauge has read 1/8 full. Tank full, tank empty, battery connected or disconnected, ignition on or off, sending unit wire attached or cut. Even, as I learned tonight with the f'ing gauge out of the dash. I figured sending unit. Replaced it. No change. Figured it was the gauge. Replaced the gauge and the new one sits at 3 o 'clock (like way over full) again whether ignition is on or off. 30 gallon tank has at most 4 gallons in it.
WTF? I have read a bunch on here and the internet posted by guys who understand electricity testing all manner of things with their multimeters. I am a C- wrench and a solid F electrician. I am pretty sure that ohms are what I want to measure but not sure which horseshoe symbol on my multimeter I need to use or what I need to touch my red and black leads to. Can anyone tell me what to test in words a slow 4th grader can understand?
FWIW, I think my sending unit ground is good. When I put the new tank and sending unit in I poly wheeled a spot on the crossmember near an empty hole till it shone like the sun and bolted the black terminal to it.
I have never hated my truck before but this is getting me close. I am not one of the proud souls here looking for perfection from a gas gauge on a truck older than I am but when I drained the tank to change it, I thought based on odometer it had 3 or 4 gallons in it and it had 20. Need better than that.
