74 blazer ignition key?
79mudder
Registered Member
Bonesteel
the previous owner had broke the key off and pulled the switch out but i think he broke more . i know the ones i have took out before just had one piece of metal in there and you could start it with a needle nose pliers but by the looks of it there is supposed to be two cause you can see where it is broke off. how do i fix this will the new switch work with out that piece? get a diffrent colum? put a push button start? thanks.
