Got a rusty '74 GMC Jimmy, not sure what one would do with it since I don't have a title for it. It does have some good stuff on it.
Factory 4.10 gear ratio D44 and 12 bolt.
Good hartop and windshield post if you wanted to convert your '76-on-up K5 to full convertible.
There won't be a motor or tranny as they are no good. T-case has been removed but its a 203 and no one wants them. Basically the rig is a roller.
I'm removing the 4" springs and installing 12" Superlift front and 8" rear springs on 4" blocks. Four shocks will be mounted, too. I have the 4" drop draglink but it needs new ends and clamps. Tires are just itty bitty ghetto setup.
I figured someone could use the parts on this to either build or use on their rig. I prefer to see if I can sell this whole before I part it out. The lift is not mounted yet as I will do so if someone shows interest and will buy it.
$1000 for everything listed above. No title. Pay Pal accepted.
