Progress. Small brass line back there runs to the oil press gauge could be cracked, loose or broken. Mine had a crack in the line.
Wouldn't it drain better if it was on the bottom?
In total nice cheapish rig congrats![]()
Tranny fluid changes only kill already messed up tranny's...
You are correct about the grooves in the rotors being from the factory. On a lot of older vehicles there were grooves in the rotors from the factory but not as an air channel. It's there to let you know when your rotor is getting too thin. When you can't see the groove any more, it's time for new rotors. There are a couple companies that make replica rotors with these grooves for people who really want that original look(typically uber expensive muscle cars).
I didn't have any tools so I just turned it, started it and made it to Discount with it backfiring like mad. Got a lot of looks from the guys in the tire bay.
They all seemed pretty amazed at the deal.
Find TDC by myself, distributer looks to be 180 out. Reinstall, crank, no start. Almost starts but won't keep running. Twist to advance, slow crank. Twist to retard, faster crank but still no start. Mess with carb, set idle screws to 1.5 turns out, adjust idle speed screw, almost starts, won't. Best is it ran for about 3-4 seconds.
Take out and rotate 180. Distributor/rotor pointing at cylinder #1. While I'm in there, I decide to clean up the birds nest of spark plug wires. Look at cap, # 1 plug wire doesn't line up with terminal #1.
Move all wires 1 to the left so they all line up with the attached drawing/rotor when pointed at 1.
Hooked up charger and went to bed. Didn't try to start it today. Maybe Monday........
part. As I'm listening to it run, I realize there is smoke pouring out everywhere. Turns out the steel oil pressure tube that I replaced with copper is spewing oil everywhere. And I mean everywhere! It's dripping down the headers and is way bigger than it appears in the photo (no scale).
