Going down a different path now.
Got a stripped down '74 K5 frame in real good shape.
A-Bomb built by Kert to fit this frame. Its still in the bare steel, no paint.
Rear spring hanger are the forward ones that are a little narrower to allow bolting on a true 1 ton rear end without relocating the spring perches. All you'd need to bolt the rear to the spring is the Shackle Flip & Switch or any shackle flip for that matter. Just need to make sure it fits a 1 ton for the narrower width.
$500 for the frame, A-Bomb and hangers. You come pick it up. I will help you load it up.
Sorry, don't want to separate because I sort of want this frame out of the shop and if I sell the other stuff, I will be forced to cut up the frame for scrap.
I'm in Ellsworth, central Kansas.
