74 K5 Clifford's Budget Rebuild
Blazer looks great! I love seeing full verts! How did the hammered black turn out? I have been debating on doing that with my frame.
I'll start posting pics of what I did in December in a hour or two. It came out nice though. It's not extremely durable like some of the other chassis specific paints but for 12 dollars a quart you can't beat it
Originally I was planning to put a good wrench 350 in the k5. As you can see I also have a 68 c10 that I had a 468 bbc built for. I drove it around but felt the the power would be better suited for the much heavier k5. So I pulled the bbc out and dropped the 350 sbc in the c10
The fenders are Chinese garbage and made it difficult to line everything up. I decided it would be easier to pull the axle than to take the front clip off again. Here's a pic of me making sure the cherry picker was up to the task
Beware the bolts supplied in the motor mount kit need a washer to prevent the bolt from bottoming out in the block. Here is a pic of the mount next to the bolt threaded all the way in the block
