74 K5 replacement doors.....?
matkes77
Austin, TX
Anyone got a good source for doors on a 74 blazer? Mine have got a bit of rust and the internal window components are a mess as well. I don't know where to find a diagram of the window and the other pieces that are inside the door. Is there an easy way to take the door apart, and are the skins that LMC sells, the only solution for this body style?
HELP!
LMC has a drawing of the internals i do believe and you could try a Haynes repair manual. as far as replacing the doors, look on craigslist and see if you can come across some. thats what i would do
Buy a good set of 76-91 doors and cut them to match the 73-75 doors. The guts are the same...
Rene
If you do cut the later model doors down don't forget to keep the 73-76 specific braces out of your old doors to put into your new doors.
Cheers,
Rufus
I'm reskinning the lowers on my 71 just cuz i'm partial to my original doors. I'd do that on yours too but it's a little bit of work, but worth it in the end.
